   [Multi Encoder] Encoder
Multi Encoder is able to encode using two or more encoders simultaneously.
Compression Options
Add Encoder adds a new encoder, the encoder selection page is very similar to Video Converters:
Output To sets the folder and file naming converted files are saved: Important: When using multi-encoder the source video file (file converting from) must not be overwritten, this can lead to unpredictable results.
DSP Effects just as with Video Converter DSP effects, or actions (such as changing the ID Tags) can take place whilst converting.
Back To Main Index
