   AVI Encoder
Audio Video Interleaved (AVI) is a container format which can store a variety of compressed video formats, ensure compatibility with the player before encoding a large number of files. Supported video encoders:
Extension: .avi
Compression Options
A [copy no encode] option is present, if the source file is already containing the video format required it can be copied straight to an AVI container without re-encoding.
In addition are various Nvidia / Intel QSV and AMD hardware accelerated encoders, a compatible graphics cards and modern drivers are required to use those.
Back To Main Index
