dBpoweramp Music Converter        { Help Index   >   Opus Codec }
Opus is a lossy audio codec, designed by the Internet Engineering Task Force. It is a modern codec suited well to streaming (low latency).
Supported by this Codec
Compression Options
Opus offers three types of encoding:
Advanced Options
dBpoweramp Control Center offers advanced options for this codec (dBpoweramp Control Centre >> Codecs >> Advanced Options):
Decoder Options
Output can set either 16 bit, or 32 bit floating point
Sample Rate, as Opus internally stores all samples as 48KHz this option controls how to decode audio.
Command Line
dBpoweramp (Windows) allows compressions from the command-line, commands specific to this codec:
-bitrate [level]       set encoding bitrate
Example:   "c:\program files\illustrate\dBpoweramp\coreconverter.exe" -infile="c:\afile.wav" -outfile="c:\outfile.opus" -convert_to="Opus" -bitrate 128
Terminology
Back To Main Index
