dBpoweramp Music Converter        { Help Index   >   Monkeys Audio Codec }
Monkeys Audio is a lossless codec, meaning no audio quality is lost whilst compressing (unlike lossy codecs such as mp3 which throw audio data away), audio compressed to a lossless codec will be decoded identical to the source, think of it as zip for audio. All lossless codecs compress around 2:1 at best, a 3 minute audio track will be around 18 MB.
Supported by this Codec
Compression Options
Being a lossless codec there are not many options to set when compressing to Monkeys Audio:
Compression affects how much effort goes into compressing the audio, all compression modes decode identical, the higher modes compress to smaller file sizes, but will require more CPU time to compress and decompress. Fast requires the least compression time, whilst Insane the most.
Codec Background
Invented by Matt T Ashland (J River employee), one of the more efficient lossless codecs with excellent compression rates. APETags were created especially for Monkeys Audio.
More Details: http://www.monkeysaudio.com                             http://en.wikipedia.org/wiki/Monkey_Audio
Command Line [Windows]
-c="1000"      Fast
-c="2000"      Normal
-c="3000"      High
-c="4000"      Extra High
-c="5000"      Insane
Example: "c:\program files\illustrate\dBpoweramp\coreconverter.exe" -infile="c:\afile.wav" -outfile="c:\outfile.ape" -convert_to="Monkeys Audio" -c="3000"
Terminology
Back To Main Index
