Copies a tag to another name, for example map Artist to Album Artist. The original tag is kept, use Deletion if needs removing.
value. In the example all ID Tags are removed except the 3 listed.
Capitalization: when using meta data sources such as freedb there is little consistency between discs, this option allows character capitalization to be set. The Smart Capitalization option would create a tag 'A tag and Another' from 'A TAG AND ANOTHER'.
Import & Export Album Art to / from files.
Specify a
Maximum Art Size (pixel or KB size).
Force embedded Album Art to JPG art could be PNG which certain players do not support.
Rule Based Manipulation offers advanced programmable actions, such as:
| IF Genre=[anyvalue] | set if Genre if contains a value |
| SET Genre=Rock
| IF Genre= | set genre if contains nothing |
| SET Genre=Unknown
| IF Genre=Alt Rock | genre matches Alt Rock, set to Rock |
| SET Genre=Rock
| IF Album=Christmas | example showing setting a different tag |
| SET Genre=Christmas
| IFCONTAINS Album=Best of | for generic albums, add the artist name |
| SET Album=[album], [artist]
| IF Album Artist= | set album artist if empty (from artist) |
| SET Album Artist=[artist]
| IF Artist= | if no artist then set to unknown |
| SET Artist=Unknown Artist
Word / Character Replacement allows individual characters or whole words to be substituted with another character or word, or to be deleted when no substitution is specified.
Externally Script Tags runs an external script to alter ID Tags see
full scripting details
Multiple Artist To 'Artist1; Artist2' dBpoweramp follows standards set by tagging formats when it comes to handling multiple artists, each tag type is different. Problems arise when another programs do not follow these
standards, a program might not read the 2nd Artist when stored in a multi artist tag. This option forces all artists into one artist, separated by '; '. Be aware, programs which follow the
tagging conventions correctly will not detect 2 separate artists.
Multiple Artist From 'Artist; Artist2' does the opposite of above.
Remove Month & Day from Year takes a 1990 12 30 date and shortens to 1990.
Drop Track Count removes the count from a track number, example 4/12 becomes 4.
Drop Disc Count removes the count from a disc number, example 1/2 becomes 1.
CRC32 and MD5 can be calculated for the audio and embedded in the ID tags, note ID Tag Processing should be the last DSP effect, other effects might change the audio.
