Encode To specifies which encoder to encode extracted channels with.Split File Naming gives the choice of how the split channel files should be named.
The channel identifier is added to the end of the source filename, for example if the source file was 'sine sweep.mp3' the resulting files would be 'sine sweep_Ch1.wav' and 'sine sweep_Ch2.wav'.
There is also an option to write out more descriptive names such as _Left _Center _Back Left, etc.
Copyright © illustrate 2026, All Rights Reserved
