dBpoweramp Music Converter        { Help Index   >   [Audio Info] Utility Codec }
Audio Info is a utility codec which extracts audio details and presents them as a list, or a tab delimitated table, for pasting into a spreadsheet, such as Excel.
Designed to extract details from whole libraries of audio in one go, use with dBpoweramp Batch Converter to select whole folders and sub-folders of files in one click.
After processing the results are shown using Notepad.
Options
Extensive Audio Information extracts extra technical fields as well as ID Tags.
Tab Separated Table when checked results of all files are collated in a tab delimiter table, when results are displayed in notepad it will look jumbled, copy and paste into a spreadsheet to view correctly.
Back To Main Index
