dBpoweramp Music Converter        { Help Index   >   Apple Lossless Encoder }
This Apple Lossless Encoder (ALAC) use the Apple Open Source Library and encodes to .m4a files, both 16 & 24 bit are supported.
Portions are (c) Apple and are licensed under the Apache License.
Supported by this Codec:
Compression Options
Apple Lossless does not have many options, actually it has no configurable options, it does not need any (being lossless).
Advanced Options
dBpoweramp Configuration offers advanced options for this codec (dBpoweramp Control Center >> Audio Codecs):
m4a / mp4 Tagging
m4a Layout can be 'Optimized for Streaming' (where the audio details and tags are placed before audio data), or 'Streaming Incompatible' where audio data appears first.
Tag Padding by using padding, minor tag changes save the whole file being shuffled (as tags are generally before the audio)
Compatibility Sony and Nokia players require an id3v1 tag, whilst strictly breaking the m4a standard, this option will write those for compatibility.
Terminology Encoding:  compress and write audio track,
Back To Main Index
