dBpoweramp Music Converter        { Help Index   >   Cue Sheet Encoding }
Cue Sheets store an extra file (.CUE) along with the audio, which describes the layout of the tracks on the physical CD.
There are two types of cue sheet:
One large audio track and cue sheet tells a player how to split it into separate tracks. To create this type of cue sheet change the encoder in CD ripper to [Cue Single File Encoding],
The second type is individual audio tracks, with a non-compliant cue sheet, to create use the normal encoder (such as FLAC), and include the DSP effect CUE Sheet - Multiple Files.
Compliant CUE Sheet
Set the encoder in CD ripper to [Cue Single File Encoding]:
Encode To sets the audio format to be written.
Path and File Naming set where the combined single audio file goes. The Temp Encode Folder would normally be %tmp% to use the system temporary folder.
The resulting cue sheet will resemble:
REM COMMENT "dBpoweramp"
PERFORMER "Kanye West"
TITLE "Watch the Throne"
FILE "Kanye West - Watch the Throne.flac" FLAC
  TRACK 01 AUDIO
    TITLE "No Church in the Wild"
    PERFORMER "Kanye West; Frank Ocean; Jay-Z"
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    TITLE "Lift Off"
    PERFORMER "Kanye West; Beyonce; Jay-Z"
    INDEX 01 04:32:38
  TRACK 03 AUDIO
    TITLE "In Paris"
    PERFORMER "Kanye West; Jay-Z"
    INDEX 01 08:58:57
  TRACK 04 AUDIO
    TITLE "Otis"
    PERFORMER "Kanye West; Jay-Z; Otis Redding"
    INDEX 01 12:38:07
There is an option to write UTF-8 CUE Sheets, in dBpoweramp Control Center >> Audio Codecs 'List / Options'), change the Encoder Option for [Cue Single File Encoding], check first the player supports.
Non-compliant Cue Sheets
Multiple audio tracks are written with a CUE Sheet, which has the best player compatibility. To do so, set the encoder to a normal encoder, such as FLAC (do not use [Cue Single File Encoding]) and include the DSP effect CUE Sheet - Multiple Files.
A file Cuesheet.cue will be created in the same folder as the first file, a typical multiple file CUE Sheet will resemble:
  TRACK 01 AUDIO
FILE "01 Kanye West - No Church in the Wild.mp3" MP3
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    TITLE "Lift Off"
FILE "02 Kanye West - Lift Off.mp3" MP3
    INDEX 01 00:00:00
  TRACK 03 AUDIO
    TITLE "In Paris"
FILE "03 Kanye West - Ni--as in Paris.mp3" MP3
    INDEX 01 00:00:00
  TRACK 04 AUDIO
    TITLE "Otis"
FILE "04 Kanye West - Otis.mp3" MP3
INDEX 01 00:00:00
Terminology
Back To Main Index
